I am trying to create a BL from a surface mesh. it works more or less correct with some ‘bumps’ in the nodes where different surfaces intersect.
for the creation of the BL I am doing the following steps:
- create a surface mesh
- use extrusion/ select extrusion by normal
- select all the faces from the surface mesh and change the distance to a negative value and number of steps
also here is the surface:
faces.brep (15,7 KB)
any idea how to improve, solve this issue?
best regards,
