I compiled kernel success ,but cannot compile GUI.
it says KERNEL is not compiled. Please follow approach described at this link and use the attached script install_bin.bat to configure everything.
Finally, note that you need to install SALOME in D:\S and not D:\SALOME-master.
the sat install command should not be used here. Please follow nominal approach at the link I shared in my previous reply.
