Build Shaper in Window 10,How to set Environment param
I built Shaper in Window 10,at the shapergui_app project ,How to set GUI_ROOT_DIR、SHAPER_ROOT_DIR ?
int main(int argc, char *argv[])
constexpr char GUI_ROOT_DIR[]=“GUI_ROOT_DIR”;
constexpr char SHAPER_ROOT_DIR[]=“SHAPER_ROOT_DIR”;
constexpr char LIGHTAPPCONFIG[]=“LightAppConfig”;
QProcessEnvironment pe(QProcessEnvironment::systemEnvironment());
if(!pe.contains(SHAPER_ROOT_DIR))
std::cerr << SHAPER_ROOT_DIR << " is not defined in your environment !" << std::endl;
return 1;
if(!pe.contains(GUI_ROOT_DIR))
std::cerr << GUI_ROOT_DIR << " is not defined in your environment !" << std::endl;
return 1;
Error
Can not load application library “LightApp.dll”: 找不到指定的模块。
OK
Now I got this error!
