Build 9.13.0 shaper make install failed
use git doc : SAT · SalomePlatform/.github Wiki · GitHub build shaper
# SALOME-9.13.0/W64/Python/python.exe SAT/sat -o "APPLICATION.properties.git_server='github'"  compile SALOME-9.13.0-windows -p SHAPER --clean_all
Executing the compile commands in the build directories of the products of the application SALOME-9.13.0-windows
  SOURCE directory = F:\S\SALOME-9.13.0\SOURCES
   BUILD directory = F:\S\SALOME-9.13.0\BUILD
Compilation of SHAPER ........................ KO MAKE INSTALL
Compilation: KO (0/1)
see log:
    File "<string>", line 1, in <module>
    File "F:\S\SALOME-9.13.0\W64\Python\lib\shutil.py", line 566, in copytree
      with os.scandir(src) as itr:
  FileNotFoundError: [WinError 3] 绯荤粺鎵句笉鍒版寚瀹氱殑璺�寰勩€? 'F:/S/SALOME-9.13.0/BUILD/SHAPER/doc/gui/html'
not found doc/html;
Could you please tell me if there is anything specific that needs to be configured for compiling the doc?
The terminal displays that it cannot find the doc/html directory.
either share your BUILD\SHAPER\CMakeCache.txt file to check what could be wrong in the settings, or simply switch off documentation.
To switch off documentation, edit SAT_SALOME/products/SHAPER.pyconf and add -DSHAPER_BUILD_DOC=OFF at this line.
