is there a way to load Ensight glod case files in Paravis module?
or a utility to convert them to med file format?
Thanks for any suggestions
Best
Best
Ensight file format (.case) is supported and is indeed shipped by Paraview.
To load this file, in PARAVIS, in main menu, select: File -> Open ParaView File...
Ok great.
Any idea on howl to convert these files to med format?
I wish to try mesh adaptation with homard but my fem output are in ensight gold format not med ![]()
there is a tool in medcoupling called case2med but if i remember one discussion with Christophe, it is quite limited.
Here better proceed as follows: load the .case file in PARAVIS and in the main menu: : File -> Save Data and select MED (dump the generated python trace to check if this can be done programmatically - not checked)
