3D tab deactivated for a wing geometry
Hi
I have a .iges file of a wing geometry which I imported into geometry module. Then, I switched to mesh module to create a mesh. When I try to create a mesh, 3D tab is disabled for some reason. Only 2D, 1D and 0D are available even though shape is 3D.
I have attached the iges file with this post, any help would be appreciated!
Pavan.
wing.igs (703.7 KB)
iges only supports faces. Moreover, a face is missing to close the shell (and define a solid from it).
Find in attachment the study with the shape fixed.
Study_wing.hdf (450,6 Ko)
Hi Christophe
Thanks for the clarification! Can you describe how you closed the geometry?
Pavan.
You have a set of tools to accomplish this in the geometry module, called repair. Where you can close holes, delete surface etc. Once you closed your geometry, you can build a solid from it.
Regards
To create the new face:
  • select the 3 edges from the other faces
  • create a wire from them
  • create a face from the wire
To create the solid:
  • create a shell with the new face and the other faces
  • create a solid from the shell.
Hi Christophe
Thanks for your reply! I will look into the operations you mentioned.
Pavan.
