I downloaded Salome_meca 2025 for windows and installed it on Windows 11 and it works ok so far.
But then I switched to other laptop with Ubuntu 24.04. I downloaded the .sif file from here to a /home/jcsaaver/containers folder.
Then I installed singularity with:
sudo apt install singularity-container
And after that I did:
singularity run --app install salome_meca-lgpl-2025.1.0-1-20251026-scibian-12.sif
Then I run
/home/jcsaaver/containers/salome_meca-lgpl-2025.1.0-1-20251026-scibian-12
And the program starts normally.
But then I click on shaper module and it closes.
Here is what appears on the terminal:
jcsaaver@HP:~/containers$ /home/jcsaaver/containers/salome_meca-lgpl-2025.1.0-1-20251026-scibian-12
WARNING: Could not find any nv files on this host!
+ running salome_meca in software rendering mode
++ using container salome_meca-lgpl-2025.1.0-1-20251026-scibian-12.sif
++ using software rendering mode (should use `mesa_salome` starter)
** (SALOME_Session_Server_No_Server:9500): WARNING **: 17:31:12.668: atk-bridge: get_device_events_reply: unknown signature
X Error of failed request: BadWindow (invalid Window parameter)
Major opcode of failed request: 3 (X_GetWindowAttributes)
Resource id in failed request: 0xe
Serial number of failed request: 10
Current serial number in output stream: 11
In case it helps, these are my system characteristics:
# Detalles del informe del sistema
## Detalles del informe
- **Fecha generada:** 2026-08-23 12:00:20
## Información de hardware:
- **Modelo de hardware:** HP HP ENVY Notebook 13-ab0XX
- **Memoria:** 8,0 GiB
- **Procesador:** Intel® Core™ i5-7200U × 4
- **Gráficos:** Intel® HD Graphics 620 (KBL GT2)
- **Capacidad del disco:** 256,1 GB
## Información de software:
- **Versión de firmware:** F.07
- **Nombre del SO:** Ubuntu 24.04.2 LTS
- **Construcción de SO:** (null)
- **Tipo de SO:** 64 bits
- **Versión de GNOME:** 46
- **Sistema de ventanas:** Wayland
- **Versión del núcleo:** Linux 6.8.0-63-generic
I do not know what am I doing wrong. Any help is welcome.
