I am setting up a mesh for a CFD simulation demo of viscous channel flow past an infinitely long circular cylinder.
I have specified NETGEN 3D and NETGEN 1D-2D algorithms for the main mesh, with 3D Viscous Layers additional hypothesis specified on the top and bottom walls as well as the cylinder wall. Now I want to make the left and right boundaries of the mesh to be translationally periodic (which means the surface meshes should be conformal), in order to circumvent the need for implementing non-conformal interfaces in the solver. I have created a sub-mesh using the NETGEN 1D-2D algorithm without hypothesis for PeriodicHigh, and another sub-mesh using the Projection 1D-2D algorithm with the Source Face hypothesis for PeriodicLow.
After clearing mesh data, if I perform Compute Sub-mesh solely, the periodic (conformal) surface meshes are built successfully.
The problem is, if I perform mesh Compute, after the extrusion of the 3d prism layers, the periodic faces are no longer conformal.
This is unexpected, because as shown in the documentation the scenario of periodic faces with viscous layers has clearly been considered. Is this due to my incorrect setting or something else?
Attached is my study file. I am using SALOME version 9.16.0 on linux platform. Any help is appreciated!
Study_Smesh.hdf (5.7 MB)
